transmisson
Old Jan 24, 2006 | 10:13 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
Default transmisson
if i hit the gas somewhat hard....i can hear gears grinding.........are there any possibilities other than my transmission is about to die?
Old Jan 26, 2006 | 04:28 AM
20Blazer00's Avatar
Default RE: transmisson
I would guess transfer case or rear differential (2wd); front, rear differential or transfer case (4wd)... the only other items to check are motor mounts if one is broken then the motor can shift and might cause some items to grind against each other, but this is very rare...I remember owning a '65 Malibu and I would hear a clunk in the engine compartment when I accelerated hard from a stop....found out the previous owner beat the **** out of the car by drag racing it so I had to replace the motor mounts and that fixed the problem, got back some performance too...but I digress....
An automatic has very few "gears" in it. They have splines on the input and output shafts. And the only gears are in the "Sun Planetary Gears", these would be the only gears in the tranny that I have heard of and I have read on other boards that this is a part that does have problems for the tranny in the Blazer/S10 trucks....
Old Jan 26, 2006 | 04:30 AM
4lowlife's Avatar
Is the fluid level up to par? An auto tranny is a hydraulic pump basically
Old Jan 26, 2006 | 08:47 PM
i checked the fluid levels and they are up to par....i think i m going to bring it to the mechanic to check out
Old Jan 26, 2006 | 10:12 PM
4lowlife's Avatar
Ok, let us know what its diagnoses is.
I was thinking this spring to install a Jetperformance kit, -click- when I change filter and fluid. Not sure if I want to mess with factory set shift points though.
Old Jan 27, 2006 | 01:21 AM
Bocomo's Avatar
Bocomo is an unknown quantity at this point
I saw that in a catalog and was wondering about it. If you do install one do a report on it.
Old Jan 27, 2006 | 07:45 PM
4lowlife's Avatar
I will post one. Won't be until March when it warms up out there. It'd darn cold in the barn.
Phyrstorm
Jul 9, 2010 01:03 AM
rjck1979
Dec 29, 2009 04:15 PM
rsither
Aug 13, 2009 10:29 AM
99 Blazer 4 door
Performance & Brainstorming
Aug 29, 2008 10:46 AM
SoDakBlazer
Aug 5, 2006 06:21 PM
