trouble
Old Nov 3, 2006 | 01:07 PM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default trouble
alright, i'm having trouble removing the fan and the fan clutch. i'm trying to replace a water pump and the ****'s not coming off like it's supposed to. i've tried wd40 and that **** is still stuck on there good. oh, i forgot to mention, i have all the bolts out. figured i'd add that so i didn't sound like a 'tard.
Old Nov 3, 2006 | 01:38 PM
jpap's Avatar
jpap is an unknown quantity at this point
Default RE: trouble
heat it up!!! A torch might melt the plastic, or you can run lots of hot water over it.... also, there is some stuff out there called penetrating bolt remover or something... ive used that before...
Old Nov 3, 2006 | 05:06 PM
Default RE: trouble
It might help to know what you are working on... From one of your other posts, I see it's a '97. Please put your vehicle information in your signature and attach it to all of your messages to aid us in helping you.
I seem to remember reading that the fan clutch is held on by a LH thread (ie. righty loosey, lefty tighty). And I would definitely try a penetrating oil before putting heat to it. There actually is a special tool that is supposed to be used to remove the fan clutch, but so long as your belt is tight and not slipping, you should be able to remove the clutch.
Old Nov 3, 2006 | 09:29 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: trouble
Take your belt off and put a small pipe wrench on your water pump pulley to hold it (put a small piece of cardboard in between the teeth of the pipe wrench and the smooth part of the pulley so you don't burr the pulley up) Use a large crescent wrench to turn the big nut on the end of the fan clutch counter clockwise (no these are not left handed threads)..once you break it loose it will spin off easily by hand exactly as it's "SUPPOSED TO"....lol
Old Nov 3, 2006 | 09:38 PM
Default RE: trouble
Yeah, I couldn't remember. Was the LH thread on the reverse rotation smallblocks? Or am I just completely nuts?
Old Nov 3, 2006 | 09:53 PM
lastcoupe's Avatar
Default RE: trouble
I have heard of these lefties, but personally have never run into one. Naw you're not nuts....LOL
Old Nov 3, 2006 | 11:19 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Default RE: trouble
Head to Auto Zone and get the special tool. You can't get that pump out without getting the fan clutch off the pump.
dunontme
Jan 21, 2010 07:36 PM
fivemillerz
Jul 17, 2006 08:26 PM
luvfroses
Jul 7, 2005 11:44 PM
sully
Jun 8, 2005 08:06 AM
01xtreme
Headers, Intake, & Exhaust
Oct 5, 2004 02:17 AM
