weak startup
Old Oct 16, 2006 | 04:38 PM
blazinloud's Avatar
Default weak startup
sometimes when i startup it kinda starts weak, then surges and dosent sound very strong. happens maybe 50% of the time......would this be mainly my batteries fault? Or is there more to it such as fuel pressure or something.......?
Adam
Old Oct 16, 2006 | 05:09 PM
Default RE: weak startup
I do not think that fuel pressure would not have an impact on the starting power of your vehicle. This is typically caused by a loose/corroded connection to the battery. A dying battery could also be the source of the problem as well as possibly a dying starter. The reason why I stated the battery connections first is because it is intermittent. A loose or corroded connection will vary with temperature, humidity, etc...
Does it do this more when the engine is hot or cold? Anything else that accompanies this behavior that may help us diagnose it further?
Old Oct 17, 2006 | 02:43 AM
blazinloud's Avatar
on cold startups it starts very good and strong.........I will check the connections, but im sure there nice and clean, and probably not loose....cant think of anything else that goes to it......
and thanks for the reply kyle, ur toooooooo deadly, lol.
Old Oct 17, 2006 | 01:06 PM
4lowlife's Avatar
Your alternator may be going.
Get the alt, starter, and batt to A-zone for a free diagnostic.
Old Oct 17, 2006 | 04:50 PM
blazinloud's Avatar
alt and batt are brand new!!!!! i hope not.......maybe my stereo drains too much of the batt. juice. No autozone here......think its 25 or 30 bucks to get that checked....
ahhh well, my alt is still warrentied....anyway to check a starter? and how much is a new one? could it be the 'ignition control' thingy or no......my mechanic said they commonly go bad......or something to that effect
Old Oct 17, 2006 | 05:21 PM
guywm25's Avatar
guywm25 is an unknown quantity at this point
If after checking the battery connections the battery itself and that is not the problem, just a suggestion, when I bought my alternator at the local parts store, the "old man" behind the counter reminded me to make sure and clean the ground wire connected to the chassis, like I said it is just a suggestion.
Old Oct 17, 2006 | 05:39 PM
blazinloud's Avatar
thanks guy
My mechanic just slapped er in, I needed my truck back fast.....took em about 10 or 15 mins........
94BlazerPA
Jul 24, 2010 12:11 AM
andryscha
Dec 17, 2009 07:49 PM
Crestwood1001
Jun 2, 2009 09:02 PM
sasquatchfound
Sep 21, 2008 12:07 PM
patterrr
Oct 24, 2006 03:50 PM
