'00 Blazer eating starters...
Old Nov 17, 2011 | 10:07 PM
95BlackGA's Avatar
95BlackGA is an unknown quantity at this point
Default '00 Blazer eating starters...
I've gone through 3 starters in the past 2 months with my '00 Blazer 2wd (4.3L auto). The truck is just ruining the bendix gear in the starters. Last one it screwed up so bad the starter would engage, but just spin freely when too much torque was put to the fly wheel.
The problem is, it seems like when cranking it starts to want to fire wrong and run backwards, and kickin' HARD. I am going to upload a video tomorrow, but too dark to do it right now. Just looking for possible suggestions?
Things I have looked at :
Distributor (Replaced cap & rotor)
Plugs (Made sure they are in correct firing order)
ICM (Not replaced, works fine, 'cause truck runs excellent when started)
Any help would be appreciated, tired of buying new starters each time, or replacing them. Yeah it's a 25 minute job, but that's an annoying 25 minutes.
Old Nov 17, 2011 | 10:29 PM
xgiovannix12's Avatar
your blazer is a starter aholic? Joking
some starters have to be shimmed
did you use the same brand all the times you replaced it ?
Old Nov 17, 2011 | 10:55 PM
95BlackGA's Avatar
The first two were Ultima's from O'Reilly's, this last one is a Beck/Arnley from a junk yard (heard it start the motor right up before it was pulled).
Also, I forgot to say I replaced the Crankshaft Position Sensor also.
Eric Haskins
Jun 13, 2013 02:38 PM
scanlojs
Nov 3, 2010 01:59 PM
kpmink
Jul 17, 2008 07:35 AM
donnieb83
Jul 15, 2008 07:41 PM
mbnorton
Jul 22, 2006 07:50 AM
