01 4.3 only starts once every few hours
I have a 01 blazer 4.3 that starts great the first time but will not start again for at least an hour or two. Engine cranks and has spark. I checked for gas at the valve on the fuel line and there was pressure but do not have a gauge to put on it.
This started after replacing the motor. Is there anything I missed maybe? The motor runs great when it starts.
Any help would be appreciated
how long will it run? does it die or do you shut it off?
I just had to replace my fuel pump, constantly dying and shutting off on me.
Test fuel pressure when you are experiencing the no-start.
It stays running and there are no problems until you shut it off. then it just cranks and cranks and won't start
my guess is fuel pump or fuel relay.
I don't know exactly how I fixed it but it works great now. I started it and let it run for about 30 minutes and now it runs like a top and starts whenever you need it to. I'm thinking maybe the computer had to relearn the new motor.
kb7qdi
12-17-2012 05:54 PM
ek72
07-14-2011 11:09 PM
an240172
11-18-2009 09:32 AM
Cutler
06-08-2009 04:03 PM
