02 blazer possible oil pump bad
Old Jul 27, 2021 | 10:24 PM
02 chevyblazerguy's Avatar
02 chevyblazerguy is on a distinguished road
Default 02 blazer possible oil pump bad
I have an 02 Chevy blazer rwd 4 door
lil back story bought it couple months a ago from a guy who bought from a guy that died( his daughter sold it) the vehicle Sat for awhile according to him. I bought and everything worked fine. I live In ky and visited ny.. I just got back from ny and I was driving the ky hills on one of the mains highways and then loud ticking/knocking started in the bottom half of the engine and then my oil pressure dropped from about 40 which is where it normally sits to 20 and the ticking/ knocking continued with acceleration and at a idle .. I read thru these forms and some ppl said that after a long time sitting it could be old oil that’s clogged up on pump that fell off( cuz I did a new oil change day before I left to go to ky from ny…any ideas/diagnosis what it could be I’m trying not to have pay to have new oil pump put in
Old Jul 28, 2021 | 08:46 AM
LesMyer's Avatar
Sounds like bearings to me.
Worn bearings can cause a valve lifter to collapse at idle because oil pressure near the bad bearings is low (pressure leaking out around worn bearings) and lifters are fed off of the main bearing oil galleries..Once the engine is off idle, the oil pump puts out more volume and the pressure goes up (quieting the lifter). Noise under acceleration would be the knocking from the extra clearance in the bearing as the piston works harder.
Here's the way mine sounded with this condition - see post #1 here. Was my first post on this forum. Now it is 60K miles later.
https://blazerforum.com/forum/2nd-ge...g-valve-87514/
Old Jul 28, 2021 | 10:18 AM
The shop was saying engine could be done for as well which is what I suspected .. any price ideas
Old Jul 28, 2021 | 12:35 PM
Used, maybe $400-800, depending on mileage. New, maybe $1500-1800, plus something like 20 hours of labor.
You should also figure in new belts, hoses, spark plugs, wires, fluids, etc.
Klturi421
Nov 11, 2012 01:15 AM
Zrhighfield
Aug 7, 2010 09:17 PM
dlippiet
Jun 6, 2010 04:22 PM
vernzr2
14
Mar 20, 2008 11:02 AM
dax44
Jan 22, 2008 04:35 PM
