06 Trailblazer XLT 4x4, EVAP Monitor INC
Old Jan 4, 2016 | 09:46 PM
Rvogeler's Avatar
Rvogeler is on a distinguished road
Unhappy 06 Trailblazer XLT 4x4, EVAP Monitor INC
Bought a 06 Trailblazer XLT 4.2 V6 and can't get it to pass emissions. Ran through multiple Drive Cycles, at least 5. Started with about a 1/2 tank of gas ran it down to 1/4. Filled up to about 3/4 and ran back down to 1/4. Tried to follow the standard drive cycle procedure as best as I could. No check engine light. No error codes. But the EVAP Monitor still says INC. I have an Actron 9580 Auto Scanner but can't drill down into any EVAP test to see if anything is not logging in or holding things up. When I go into the EVAP monitor test the scanner just tells me that a command was sent. Might have reset the whole thing and it may be starting drive cycles back to the start? Any ideas or direction?
Old Jan 5, 2016 | 07:17 PM
TMM217's Avatar
TMM217 is on a distinguished road
Not to sway you from being here but try GMTNation.com for help with your Trailblazer
Microman
Jan 19, 2015 03:03 PM
WGOOD
Feb 21, 2012 05:22 PM
joanayres
Mar 12, 2011 04:42 PM
reapersimage
May 22, 2005 04:53 AM
02 Vortech
Apr 1, 2005 01:36 AM
