1200-1800 rpm vibration
Old Jan 5, 2014 | 03:45 PM
guitar134's Avatar
guitar134 is on a distinguished road
Default 1200-1800 rpm vibration
Noticed when at the above listed rpm's the motor seems to vibrate the truck pretty good. not misfire bad, but enough to wiggle the seat. its on a fresh tune up, and distributor, runs fine otherwise.
ideas on places to look?
Old Jan 5, 2014 | 04:05 PM
rockp2's Avatar
Did you check your motor mounts?
Old Jan 5, 2014 | 04:49 PM
guitar134's Avatar
i didnt suspect mounts because while under the hood, revving the motor it doesnt move excessively, i will double check them tomorrow on the lift while im doing some other work though
Old Jan 5, 2014 | 04:56 PM
rockp2's Avatar
If the mounts have never been replaced, there is a good chance at least one of them is bad. This is common. If it does end up to be the mounts, somewhere on here there is a link to some after-market mounts that are not only more durable, but of a better design for installing. Also, give yourself plenty of time to change them because Blazer mounts are the hardest to change I have ever experienced (though I am only a "shade tree" mechanic").
Old Jan 5, 2014 | 10:58 PM
Diaita's Avatar
Is it only when the engine is under load, or all the time?
Old Jan 6, 2014 | 06:45 PM
guitar134's Avatar
i notice it most when im revving it to warm it up, or at low speeds
Old Jan 6, 2014 | 07:00 PM
spittybays
Guest
Posts: n/a
Sorry new to this, first Ford or Chevy?
Year, Make and Model.
"not misfire bad" What the heck does that mean ( more info please ).
New problem or old problem.
Old Jan 7, 2014 | 12:27 PM
Diaita's Avatar
A spark plug wire not installed correctly? Spark plug with a cracked insulator? Cap/rotor not installed properly?
sgtwsky
Aug 26, 2012 11:06 AM
Aanenson
Feb 1, 2012 11:00 AM
wreckhur
Apr 12, 2011 06:30 PM
thrillbilly
Mar 20, 2009 08:31 PM
