1351 code with stumble and stall.
Old Nov 8, 2014 | 07:54 AM
Intmid8r's Avatar
Intmid8r is on a distinguished road
Default 1351 code with stumble and stall.
okay guys I have a 1995 GMC Jimmy 4.3 V6 4 wheel drive automatic trans with a 2500-3000 rpm stumble / miss / stutter whatever you wanna call it then stall under load. I have replaced cap and rotor, wires, coil, ICM, plugs, oxygen sensors, MAP sensor, crank sensor, IAT sensor, spider injector, fuel filter, fuel pump, and it still does it. now when I changed the TPS sensor last night it went from being under load to it does it under no load now and when driving with a load on it it seems fine. the only code I'm getting from the scanner is a 1351. any help here would be awesome guys I'm starting to run out of ideas
bige97blazer
Dec 25, 2013 11:36 AM
Spookypaws
Jan 15, 2013 05:52 AM
blazer chris
Dec 8, 2011 09:56 AM
Straka88
Nov 3, 2011 06:19 PM
Iceman_19
Aug 26, 2009 03:14 PM
