1984 Blazer S10 w/ 3.4l engine Won't Start!
Old Dec 12, 2008 | 11:02 AM
Default RE: 1984 Blazer S10 w/ 3.4l engine Wont Start!
Not sure how carfax can help identify the carb used on a motor swap, but...
If it is the stock 2.8L carb, then it should be the 2SE although if the truck were to come from California, it could be the E2SE carb having electronic controls on it. I would bet that it is the 2SE. I was able to find a few good references to the Rochester 2SE carburetor using a quick google search. For some reason I could not post the links into this thread, but have a go at doing the search yourself and you should find them.
Old Dec 12, 2008 | 12:17 PM
onecrazyfoo4u's Avatar
onecrazyfoo4u is an unknown quantity at this point
Sweet thanks for the info! I'll check for the model number on the carb when I get home. I am in cali, so it might have the electronic controls one. I'll see what I can find on it! Now I just need to find a vin or model for the engine itself, so I can google that info....
Old Dec 13, 2008 | 09:34 AM
Hanr3's Avatar
Look for a flat tab on the head up front, passeners side.
Old Dec 16, 2008 | 09:25 PM
VanHalen's Avatar
VanHalen is an unknown quantity at this point
Perhaps something (sensor) on the engine is reading wrong, thinks the engine is running lean, and is flooding the engine? I had problems with mine starting up for a while, but honestly after I put the HHO generator in my truck, it starts a lot easier
Old Dec 17, 2008 | 11:20 AM
What is this HHO generator your talking about, just a fuel injection swap? I got her started up after a little work. It was just a stuck chock plate on the carb, just fiddled with it and cleaned her up and she runs like a champ now. The rear plate on the stock 2BBL carb is the choke plate right? That's the one that I had to mess with.
Thanks for the help all, now I just need to find vin and model numbers for future reference, just in case!
gmoneyeagles
Dec 11, 2014 10:53 PM
sammm
Sep 14, 2013 11:21 PM
Russel Panke
Dec 31, 2012 01:12 PM
grapeape3
Aug 19, 2012 03:25 PM
503blazerluv
Mar 16, 2009 08:04 AM
