1984 Blazer won't stay running
Old Aug 17, 2012 | 01:51 PM
grapeape3's Avatar
grapeape3 is on a distinguished road
Default 1984 Blazer won't stay running
Ok, I've got a good one. My step son ran out of gas, while trying to sneak some from us he grabbed the wrong gas can and put about a gallon of weed killer in the tank and ran it for a short time (10-15min). We have pumped what we think is everything out of the tank and have replaced the fuel filter. However the truck will start but it won't stay running unless you continously pump the gas.
Any suggestions?
Old Aug 19, 2012 | 03:25 PM
abig84's Avatar
that is a good one and a new one. i woul d just pump everything out like you said you did then fill the tank to the top with good clean gas. also if possible, since its a 84 it should have the manual fuel pump on the side of the engine, disconnect the line going into the carburetor put a rubber hose or something on that line so you can get it into a clear container then just crank the engine til it sprays out all that crap and the gas looks clean then hook the line back up to the carburetor. thats what ive always done when working on cars that sat for a very long time or after putting a gas engine into a diesel truck, flush the tank and the lines.
if you dont want to go through all that, you might be able to just fill the tank and let it run it should dilute it enough to make it run good
turbotype87
Jul 16, 2011 09:15 PM
thays0407
Mar 8, 2011 03:55 PM
Lazt36
Mar 13, 2008 05:11 PM
Dizgt
Sep 10, 2007 09:21 PM
jes9999
Mar 12, 2006 01:40 AM
