1985 blazer 2.8 knock; need help diagnosing.
![Thumbs down](https://blazerforum.com/forum/images/icons/icon13.gif)
1985 chevy blazer 2.8 automatic carb.
Since I got this car it's had a constant knocking sound from the front of the engine. I put 20/50 oil in the engine at the last oil change and now the knocking is randomly intermittent. Doesn't matter if it's cold/hot; sometimes it knocks and sometimes it doesn't. Occasionally I can hear it get louder the higher the RPMs go. I just want to know exactly what is wrong or making that knock so I can fix it.
Im having a similar issue with my Blazer but the knocking only happens when the engine has warmed up. I hear it at Idle and just before the engine shifts but only between the 1st 2 gears. Someone told me to add 20/50 motor oil in due to it being a higher mileage engine. Prior to changing the oil, was your Blazer ticking all the time? was it Rhythmic? Possibly louder just before shifting? Any idea which part of the engine your knock sounds like its coming from?
neksys
02-05-2012 04:32 AM
glamisfanatic
05-10-2011 07:14 PM
WolfPack
13
04-07-2011 02:51 PM
rknight
03-07-2010 05:48 PM
