1986 s10 blazer engine swap info
Old 10-13-2012, 05:47 PM
fords4wheeling's Avatar
fords4wheeling is on a distinguished road
Default 1986 s10 blazer engine swap info
Hello . Im looking at buying a 1986 s10 blazer 4x4 5 speed with a blown 2.8 v6 . I was wondering if there are any companys that make an adapter to bolt either a 4.3l v6 or a 350 v8 up to the stock manual transmission ? . or is the only option to swap in a different transmission with the new engine ? . thanks for any infomation
Old 10-14-2012, 10:00 AM
neo71665's Avatar
Advanced adaptors makes a plate but honestly I'd get the right trans over adding one more part to go wrong. The v6 trans in these things are weak from the factory so if you wanting to go bigger engine its a good time to put a trans in it to handle something.
Old 10-15-2012, 04:55 PM
Ok cool . Yeah i'll probably swap in a different trans if i end up getting it and decided to swap in a 4.3l or a 350 . Thanks
bobditts
11-06-2010 10:43 PM
Shawn F.
07-22-2009 08:35 PM
ElGatoAzul
03-30-2009 10:47 AM
expensive_habit
Engine & Internal
09-18-2008 08:43 PM
kdicker1
07-27-2006 11:53 PM
Quick Reply: 1986 s10 blazer engine swap info
