1991 chevy s10 not going into park
Old 09-03-2013 | 03:11 AM
blazintheway's Avatar
blazintheway is on a distinguished road
Default 1991 chevy s10 not going into park
i have a 91 blazer and it wont go into park.....i say its because the linkage is off but my friends dad said it could be the fork in the tranny that puts it in park or something like that.....well i need help on fixing it because im tired of putting my 4 way under my tire every time i have to park...please help man....peace..love...and blazer power!..also i cant find anyone with the same year and same problem i already searched other threads
Old 09-03-2013 | 08:55 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
ok, does it "go" into park but not stay still or will it not physically move onto park. If it clicks into park but not stay still its the park pin inside the trans. Fix your parking brake and get used to it
Old 09-04-2013 | 09:05 PM
it says park but doesnt engage....and when i start it up it flys in reverse....so basically park and reverse is the same damn thing
Old 09-04-2013 | 09:51 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
Sounds like your linkage is off. Try adjusting it, see if that helps.
Old 09-04-2013 | 11:55 PM
how can i adjust it?
Old 09-05-2013 | 09:29 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
theres not really nothing to adjust on these earlier ones. Newer ones had cables,which would stretch. look at the linkage at where its mounted against the frame beside the trans. there should be a spring and a plastic spacer in that backet. sometimes they break and fall out. with this you can have loose floppy linkage down there and it can cause issues. Other then that there is not adjustment. All you can do is safely engage the brakes,drop the trannys pan and take a look at the bracket thing the linkage slides upon inside the trans. see if its worn down.
myhotrod1968
07-31-2011 10:21 PM
randrm
01-25-2011 03:51 PM
ffalan
08-01-2010 11:49 AM
Hiddenfarce
05-25-2009 12:21 PM
Boiler_81
12-02-2008 11:04 AM
