1992 engine into 1996.
Old Feb 14, 2011 | 07:53 PM
S10Blazer's Avatar
S10Blazer is an unknown quantity at this point
Default 1992 engine into 1996.
Hi, I ordered a GM rebuilt engine at my local shop to be installed on my truck. The engine that arrived is part # L4392W that says it's for a 1992 4.3L Blazer W code. I have a 1996 S10 Blazer LS 4.3L W code 4x4 with california emissions. The shop says it will fit and that it will work. Will there be any problems, or will it work fine so I can straighten things out? Thanks.
Old Feb 14, 2011 | 11:19 PM
JustJerry's Avatar
JustJerry is on a distinguished road
Did you get a short block, long block, or complete engine? If its a short or long block everything will probably work A OK.
Old Feb 14, 2011 | 11:28 PM
S10Blazer's Avatar
It's a long block with the heads on it. From the little info I've found, I think that the heads are different and that the timing cover is not the same, but I'm not sure.
Old Feb 14, 2011 | 11:41 PM
chevycrazy2011's Avatar
chevycrazy2011 is on a distinguished road
hope the oil pan will fit in it.. i had a 93 motor out of a 2wd that wouldn't work in my 4wd
randrm
Jan 25, 2011 02:51 PM
pilot435
Oct 31, 2010 08:46 AM
SureShooter29
Mar 18, 2010 03:02 PM
poepoe624
Jan 10, 2010 11:48 AM
Boiler_81
Dec 2, 2008 10:04 AM
