1993 S-10 Hard shifting from 1st to2nd gear
Old Apr 6, 2009 | 03:04 PM
Falconator's Avatar
Falconator is on a distinguished road
Default 1993 S-10 Hard shifting from 1st to2nd gear
Hello My 1993 S-10 Blazer hard shifts from 1st to 2nd I have change the trans. filter ,fluid and replace the trans. mount but i notice that the trans. bolts are missing from the trans. to the mount. Would this cause the hard shifting? P.S and it sometimes hard shift from park to drive and from park to reverse
Old Apr 6, 2009 | 03:23 PM
deadbuzzard's Avatar
deadbuzzard is an unknown quantity at this point
very possible that that would account for it hitting hard than normal...
Old Apr 6, 2009 | 08:58 PM
You may be feeling the drivetrain shift while the transmission changes gears. Get that bolted down properly and then see if the problem persists.
Old Apr 6, 2009 | 09:12 PM
LS Twins's Avatar
LS Twins is an unknown quantity at this point
Shifting hard? not really a bad thing! Shifting LATE and HARD? Maybe something a sign
of thing's going south.
Is this shift issue new? how long have you owned your truck?
Old Apr 7, 2009 | 01:20 PM
Falconator's Avatar
Question
I am having trouble lining up the tranny mount to the cross member. When I attached the the mount to the trannt it's off to the left about 1/8 to 1/16 inches ( using the front as a point of ref.) I kept the old mount, tried it same results
Yes. This has been going on about 1 1/2 to 2 Months I have had the truck about 4 years
re: Hard Shift Problems
Old Apr 18, 2009 | 06:46 PM
art's Avatar
art
art is on a distinguished road
I have 98 model and engine light came on with a code (cant member #) took it to a tranny place and they replaced a solenoid/valve type thing. the whole problem started with hard shifting between 1st and 2nd gear
Old Apr 19, 2009 | 07:15 PM
*Moving to Engine & Transmission*
If it is off to the left or right, just push the transmission over until it drops in. It should be able to move a bit to line up.
Art, please start a new thread in the appropriate tech section for your problem. As these two years are quite different in transmission controls, it would be best to keep these two issues separate.
Daryllee
Mar 21, 2015 11:08 AM
kaleys1
Apr 20, 2013 11:04 PM
pbd3mon
Jan 17, 2012 08:50 AM
stepjl
Sep 25, 2010 12:17 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
