1994 blazer vortec v 6
wife has a problem. blazer ran fine but won`t start. it is getting gas past the fuel filter and spark at the plug. she said it was hard start just before. think may fuel system thanks in advance steve corum
RE: 1994 blazer vortec v 6
Do you have a TBI (traditional round air cleaner) or CPI (black plastic cover with orange lettered 'Vortec') engine?
I would get yourself a fuel pressure gauge and hook up to the test port on the CPI engine or install the adapter (not included in most kits) if TBI. The CPI needs 55+ psi for proper operation while the TBI needs around 15-18 psi.
cpi needs 60 pnds,i just replaced a pump on mine not too long ago.try the gauge.
well just replaced the pump about 2 yrs you think it might be bad
As I said, 55+ is what the FSM states for both the CPI and the SCFI. You really need to get a gauge on it to check the pressure. You will also want to observe the fuel pressure after you turn the key off. If it drops, then you have a leak in the system. And for the CPI motor, this is typically the FPR.
ussexplorer
03-31-2014 09:00 PM
dkvde1
09-28-2009 03:06 PM
96blkblazer
02-26-2009 04:29 PM
