1995 Blazer with blown engine
Could someone help me understand what year 4.3l vortec motor I could replace this engine with if I can't find a 1995. I want to just pull this motor out and drop a different one in. Also what is the difference with the top or side mounted spark plug wires to cap?
If you have the EDI distributor (horizontal mounted plug wires at the cap), you'll have to find another EDI '95 for it to be a direct drop in. The standard ignition system used in the early '95's (vertical mounted plug wires at the cap) did not use a CKP sensor on the front of the engine. The short block from a '96 would work, however you would have to swap over the heads on up from your '95 motor. The cam would be different as well, but probably negligible in terms of noticeable performance difference.
If you don't have the EDI distributor, then you should be able to use any '93-'95 CPI engine.
limited edition 1
Jan 27, 2023 11:07 AM
tperk77
Apr 30, 2012 10:11 PM
98Ltblazer
Nov 21, 2010 02:24 PM
1995, 43, 95, blazer, block, blown, caps, chevy, ckp, difference, distributor, engine, horizontal, motor, motors, mtor, sensor, swap, transmition, vertical
