1995 distributor problems / code 1345
Old Feb 16, 2010 | 09:08 AM
You have received advice you have not acted on... Just dismissed.
Old Feb 16, 2010 | 10:44 AM
nineteensixtycaddy's Avatar
nineteensixtycaddy is on a distinguished road
??? I'm perplexed. The only thing I haven't done is look at different timing plate covers side by side. and given that the original was returned with the bad block.. are there any pictures I can look at?
Other than that.. I don't know what I'm missing.
Old Feb 26, 2010 | 09:58 AM
Default 1345 Solved :)
Sensors.. were good.
Distributor... was dead on.
Timing Cover... was perfect, sensor in proper location
OBDII ran test on non-running engine... good
test on running engine... NO good.
So... what gives?
Wiring harness... pinched... wire damaged.
So... replaced wire
and...
test non-running... good
test---running... NO GOOD again.
Uhm... sensor is magnetic... magnetic pulses travel through the wire to count how many rotations... and the wiring harness runs right next to the spark plug wires.... DUH!!!!!!
Insulated wire seperately, and then re-insulated entire wiring harness.
Test non-running... good
test running... GOOD!!!!
no more 1345
lilblazer
Oct 8, 2013 02:13 PM
optimus485
May 12, 2012 07:07 PM
tim68
Feb 7, 2011 07:00 PM
sempre4u
Dec 16, 2010 04:34 PM
kuraki
Dec 3, 2008 11:20 AM
