1995 Engine Transplant
Old Feb 13, 2017 | 09:57 AM
LesMyer's Avatar
Originally Posted by Bromley1
I noticed the ordering code for the 1995 and 1996 engines was the same. Could that mean they are the same engine and are in fact thus interchangeable?
The later 1990s engines will bolt into place. The problem is not being able to install and use the 1995 CPI Intake Manifold and fuel injection on the later 1996+ heads (which were changed for the new SCPI fuel injection). At least that is how I understand it.
Display photos (click on "info") for the AC/Delco intake manifold gaskets on Rock Auto for 1995 vs 1996 and you will see why.
I believe you can use the short block for later engines in a 1995, with the 1995 heads as long as it isn't a metric block (casting number ****090M). Metric block is tapped for metric starter and bellhousing bolts which can cause some starter issues even if you use metric starter and bellhousing bolts.
kevlar974
Jul 11, 2011 05:01 PM
Dieselmann92
Jan 7, 2011 06:37 PM
myinkfreak
Oct 18, 2009 07:41 AM
mpaczosa23
Nov 18, 2008 06:31 PM
butterbean5570
Feb 22, 2008 01:51 AM
