1995 VIN W S10 Blazer 4x4 Engine hesitates, RPM goes up and down
Old Jul 23, 2019 | 02:15 PM
christian1984's Avatar
christian1984 will become famous soon enough
Default 1995 VIN W S10 Blazer 4x4 Engine hesitates, RPM goes up and down
Hi guys,
I don't know how to describe my problem.
First, I'm german, so please be patient and correct me, when I use the wrong words.
I start with the car. It's a 1995 S10 Blazer with the VIN W Engine and 4x4. Should be an CMFI.
I can start the engine, but in N, R and D the RPM goes up and down, and often almost dying. When push the Gas Pedal down the engine accelerates, but during the rising of the RPM it hesitates. I made two vids, of it, so I hope it can describe the Problem better than me.
It seems to be better in N, and P/D is pretty bad.
https://youtu.be/oxJJbj1wtHc
https://youtu.be/2I78RbfCpnU
replaced the IAC, TPS, Oxigen Sensors, coolant temperatur Sensors, Crankshaft and Camshaft Positioning Sensors. Next Step is the Injection Spider, and the hoses.
Fuel pressure is a little low, but still in normal region.
I would be really thankful for your help with this Problem, because in germany is no Mechanic, who can fix it.
And the last thing is the question, what are these parts with the hose? They are mounted on the drivers side of the Intake Plenum.
Thanks for your help.
Old Aug 8, 2019 | 10:11 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Mostly this happen when you have bad injectors. Did you check the spark plugs to know if it run with rich or lean of fuel.
Old Aug 10, 2019 | 02:20 PM
Hi. Today I replaced the injectors and fuel lines, but the Problem stays the same. Monday I will change the MAP-Sensor.
Old Aug 14, 2019 | 12:42 PM
So, I've got an Update. On monday I replaced the MAP-Sensor without any changes.
So I replaced the Crankshaft Positioning Sensor Ian have seen some scratches caused by the wheel inside of the Timing Chain Cover.
I measured the depth of the scratches and made a shim, 1mm between Sensor and Timing Chain Cover.
Now the Blazer runs good. Soon I will replace the old sensor with a new one.
Matthew Anglin
Mar 8, 2019 10:13 PM
MountainDew
Aug 17, 2017 01:39 PM
TZFBird
Oct 9, 2015 06:48 PM
yaya_racing
Jun 24, 2012 01:49 PM
slkovach
Jan 21, 2009 08:04 PM
