1996 Blazer Engine Locked Up
Old Dec 29, 2008 | 03:16 PM
hbnr86's Avatar
hbnr86 is an unknown quantity at this point
Default 1996 Blazer Engine Locked Up
The engine in my blazer locked up after only owning the car for1 month. I spent 1300 to buy it, the interior and exterior are perfect, the 4x4 works and the trans shifts just fine. Is it stupid to replace the engine seeing as how it will cost more than what i paid for the car probably? I hate to see it go to scrap when it is in such good looking shape. Basically im looking for opinions on whether or not it is worth it to replace the engine whe the rest of the car has 164,000 miles on it? If you think i should replace it then what is the most reliable/cost effectiveway to go (new engine/refurbished engine, etc..?)???
Old Dec 29, 2008 | 03:30 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
Default RE: 1996 Blazer Engine Locked Up
Why did yours lock up? What about rebuilding yours? Do you think it would be worth putting the money into?
When I threw a rod in mine, after owning for only 3 months, I just went with a v8. It was more problems than I thought.
If you think it would be worth it to put a motor in it, then look around and compare prices between a new and remanufactured engine. Most of the time, a reman'd engine will have the same warranty as a new one, if not more.
Old Dec 29, 2008 | 04:12 PM
hbnr86's Avatar
To be honest when it come to really getting into the engine i dont know alot so im not sure why it locked up. My guess is that it was a rocker arm broke off. The only reason i think that is because it had a slight knock before it locked up and i was told that it was probably a loose rocker arm, and i was going to get around to tearing the engine down an tightening it up, but obviously i didntdo it soon enough.
Old Dec 29, 2008 | 08:40 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Look around on Craigslist and eBay. I found a Blazer engine for my Astro (4.3L vin W) for $200, already pulled from the truck, on Craigslist. The guy sent me vids of it running right before he pulled it for a V8 swap.
It is worth it if everything else is in good/great shape as you say.
jtbwatson
Oct 18, 2013 07:23 PM
GNRFreak69
Mar 19, 2010 09:48 PM
pendrin2020
Sep 18, 2009 11:16 PM
KarenC
Feb 13, 2009 07:02 AM
michellesmark01
Engine & Internal
Jan 21, 2006 07:30 AM
