1996 s10 blazer transmission
Old Jan 19, 2013 | 04:05 PM
dave vazquez's Avatar
dave vazquez is on a distinguished road
Default 1996 s10 blazer transmission
My transmission dip stick got stuck in tube and would not release. Pulled pan and noticed that it gets stuck on the end stick curled end on a small metal flange attached to the transmission. Is this metal flange or bracket required or can i remove it, also what is this bracket for?
Old Jan 19, 2013 | 04:08 PM
Also, transmission will not shift into third gear. 1996 s10 4.3 , 2wd 247,000 miles
Old Jan 20, 2013 | 08:34 PM
medivh25's Avatar
medivh25 is on a distinguished road
If you are refering to the bracket attached to the valve body, pretty sure it is there to stop the dipstick from going cray in the case. You say no third, do you have 4th? With those miles Probly looking at a rebuild soon regardless.
Old Jan 21, 2013 | 02:19 PM
Blazer only lets me go into 1st and 2nd. I get up to 40 - 45 and no shifting. I believe the bracket is attached to the valve body if that is the aluminum casing. Can I remove it or will it do damage? Or do I cut the curled loop from the end of the dip stick. My 04 chevy Avalanche has the same style dip stick and almost the same problem with the shifting, not going into 3rd. It has only 110,000 miles on it. It went bad before my Blazer. Any ideas on that one? Trams shop told me they both have same size trans. Help if you can
Old Jan 21, 2013 | 02:40 PM
goredawn's Avatar
goredawn is on a distinguished road
Try to fix the bottom of the dipstick. The dipstick gaurd on later models might fit, they are shaped better. On the tranny, find out which it is exactly and search the forum, most 4l60e, 700r4, 4l80e, etc are covered pretty well here and you can usually diagnose the problem best by reading.
Old Jan 21, 2013 | 05:38 PM
medivh25's Avatar
sounds like the 3/4 clutches are burned up, is the oil brown?
Old Jan 30, 2013 | 08:13 PM
Default Installing new trans on my 96 s10
I am installing a rebuild on my 96 s10 blazer and I need to know all the tricks and things to look out for and what not to do's. My step son ( who is the real mechanic ) is helping, but every little bit will help us tremendously. Also, what is a good price for a rebuilt with 2 year/24,000 mile warranty?
bryanhodki
Dec 28, 2013 08:11 AM
TJ_WHITTLE
Dec 18, 2011 09:36 PM
bbmyers
Dec 5, 2011 12:56 AM
S10Blazer
Engine & Internal
Oct 3, 2006 08:24 PM
mjjrkb
Engine & Internal
Apr 17, 2006 03:02 PM
