1998 4.3 to 1995 w 4.3
Old Jun 2, 2009 | 10:00 AM
STEVELINDERT's Avatar
STEVELINDERT is on a distinguished road
Default 1998 4.3 to 1995 w 4.3
I have a 1995 s-10 blazer and have a motor out of a 1998 blazer. Will this 1998 motor work in the 1995 if i swap the intake and the heads. Are there any other parts that need to be swapped re: Oil pan sensors ect...
Thank you in advance for any input as my truck has been sitting with the blown motor for 4 years now.
Steve
Old Jun 2, 2009 | 10:12 AM
You will have to use the pan from the 95 and I am not sure if you would be able to use the front cover from the 95 or even if it is necessary... I do think that it is due to differences in the mounting and configuration of the CKP sensor for the 98... Other than that, there should be other small differences between the blocks that probably will not impact the swap much.
mark1621420
Feb 22, 2010 11:16 AM
fmmotion
Dec 12, 2009 11:13 PM
Blazerguy946
Oct 30, 2009 08:42 PM
thanser
Dec 7, 2005 05:18 PM
jezter69
Engine & Internal
Jun 30, 2005 04:53 PM
