1998 Blazer has Exhaust gas in coolant
Old Dec 10, 2019 | 08:22 PM
jetmac's Avatar
jetmac is on a distinguished road
Default 1998 Blazer has Exhaust gas in coolant
For exhaust gas leaking into my coolant should I use the Seal-Up from Blue Magic or Bar's Leaks 1111 Block Seal Permanent Head Gasket Fix or Bar's Leak HG-1 HEAD SEAL Blown Head Gasket Repair or Steel Seal or Blue Devil Head Gasket Sealer
Old Dec 11, 2019 | 10:22 AM
Personally, I would determine where the leak is (probably head gasket) and fix it the right way.
Old Dec 12, 2019 | 06:15 AM
As for the products you ask about try getting the manufacturers user manual or instructions.
It all depends on the severity of the leak. Usually it's not possible to tell where it is leaking into the water jacket but in most cases it's on the head gasket.
Try to find the manufacturers recommendations on the products you ask about such as these:
http://www.goss.com.au/assets/Upload...nformation.pdf
https://barsleaks.com/gaskets/dealin...ad-gasket-fix/
I agree with Tom on the real fix but the it's becoming expensive. Minor leaking may be cured by these products.
A leaking head gasket also means water may go the other way and fill a cylinder or seep in and cause corrosion, rust, etc.
Unfortunately that usually means pulling the heads, new gaskets, even the need for machining or a new head.
Old Jan 3, 2020 | 01:21 PM
Mods's Avatar
Time to pull the heads, its about 15 dollars for a pair of Fel-Pro headgaskets and about 16 for headbolts. Good luck.
Old Jan 3, 2020 | 01:57 PM
LesMyer's Avatar
I would not recommend the use of any sealing goo. Can make a real mess of things. Pull the heads and also have them inspected for cracks.
Old Jan 4, 2020 | 06:56 AM
jetmac's Avatar
Thanks for all of the great input.
I went with the Bar's Leaks HG-1 Worked as advertised.
Old Jan 4, 2020 | 01:02 PM
I hope, for your sake, that it continues to work.
Old Jan 7, 2020 | 03:30 PM
jetmac's Avatar
Awe man thanks but it's not a life or death situation
Old Jan 7, 2020 | 03:32 PM
No, I'm sure it isn't. It's just that, in my experience, those fixes tend to fail spectacularly at the most inconvenient time, when I'm as far away from home or civilization as possible, lol.
Old Jan 7, 2020 | 05:01 PM
Zenith's Avatar
Zenith is on a distinguished road
I used the same stuff on my blazer when I purchased it two years ago knowing that it had a small head gasket leak. It lasted about 2 months, and when I didn't expect it, the head gasket failed and what an inconvenience that was as I was many, many miles from home.
I thought it would last a few thousand miles until I decided on my new engine.....I thought wrong.
It's a quick/temporary fix only.
BTW, I had to replace my radiator and heater core as that crap sludged everything up.
J.R. Clay
Mar 17, 2011 08:22 PM
road1420
Mar 12, 2011 03:09 AM
BC1
Nov 14, 2010 10:55 PM
nova72
Apr 24, 2009 07:02 AM
creisenger
Apr 15, 2005 12:12 AM
