2 TO 4WD shift problem
Old Nov 2, 2009 | 11:51 PM
kzikyoshi's Avatar
kzikyoshi is on a distinguished road
Default 2 TO 4WD shift problem
I have a 2002 S-10 Blazer with intermittent problems shifting from 2 to 4WD and back. Three buttons are on dash. Here's my scenario:
---About 2wks ago went to shift from 2 to 4WD and dash light just flashed.
---Tried what manual said about shifting to neutral/park, but never worked
---Problem is intermittent with no apparent rhyme or reason. May work 20 times in a row, perfectly, and few minutes later, not work at all. Can be dry/rainy/hot/cold....makes no difference.
---Sometimes, push dash button once and it works. Sometimes, when button pushed it flashes on/off for about 10 seconds. Sometimes, when button pushed, it flashes once. I'm usually going from 2 to 4 WD although a couple times it took a while until it would shift back to 2 WD. I can push the button 20 times and it won't change. Then 5 minutes later it may or may not....i just wait and try it "later". Eventually it will work. I always hear clicking from module when I push button.
---Pulled off passenger side panel and visually checked connections at module. all looked fine/no corrosion.
--Replaced transfer case switch...no difference. Did find small amount of what looked like tranny fluid at vacuum connection on switch. Replaced vacuum actuator,(old one seemed to work fine. Held diaphragm in when 4WD engaged)...no difference. Vacuum lines at transfer case switch and actuator seem tight.
---Took vent fitting apart at radiator making sure it's clear. That is just a vent, right, not a check valve or one way valve? There's no rubber seat/ball like a check valve would have, so I figure it's just a vent opening.
---For what it's worth, in case there's a tie in. Several weeks ago I had a small leak at heater core as I could smell antifreeze. Water level never dropped enough to notice. Never had liquid visible anywhere or wet floor. Used Bar's Stop Leak. I only mention it as I thought it possible anti-freeze corroded a vacuum line. But then it would be a continuous problem.
---Cable to vacuum actautor seems free, no binding.
---I'm guessing only things left are transfer case motor assy. or the control module behind passenger foot panel. I'm leaning towards encoder motor assy. since I hear module clicking when shift buttons pushed. Or am I totally missing something here? How much work is involved in transfer case encoder replacement? I have a solid mechanical background....it's just the 4WD stuff is all new to me.
Any help would be greatly appreciated.
Thanks,
Dave
Old Nov 3, 2009 | 07:14 AM
Please limit your question to one thread on one topic. Double posting is against forum rules. Thanks!
*Thread Closed*
Digitized
Jan 12, 2014 12:07 PM
riggermm
Nov 4, 2009 06:06 PM
EnyChevyUK
Apr 22, 2009 12:30 AM
waterskier98
Mar 4, 2009 03:15 PM
Blahman20
Nov 3, 2008 09:45 PM
