2000 Blazer 4 door stuck in 4Lo
Old May 3, 2021 | 04:20 PM
fishycamper's Avatar
fishycamper is on a distinguished road
Default 2000 Blazer 4 door stuck in 4Lo
I have a new to me 2000 Blazer LT with the 4 button 4WD system. I recently had water get into my TCCM after some heavy rain, which caused my 4wd to shift into 4LO when I started it and after replacing the TCCM and button panel (had problems not lighting up all the time) it still wouldn't shift out of LO.
I decided to replace the encoder motor as well because that seemed to be a common problem. After replacing the motor, and replacing the battery, the transfer case finally said it was in neutral. When I tried to switch to 2HI it was blinking for a while but didn't switch and eventually I heard it switch and the light changed to 4LO.
Now the 4LO light blinks when I turn the truck on. It is in 4LO, I can drive it and it engages the front axle, but the light keeps blinking unless I try to switch, in which case the button I press blinks and 4LO is solid.
Any help is appreciated, I've basically replaced the entire 4WD system at this point. I read it's easy to mess up the encoder motor install so maybe someone can tell me if that happened. Thanks in advance!
Old May 12, 2021 | 09:20 AM
LesMyer's Avatar
Did you check the (25A) ATC fuse in the underhood fuse panel?
Chris Edwards
Aug 31, 2022 11:19 PM
Figuarus
Aug 26, 2019 09:11 PM
ramuh2121
Jun 10, 2013 04:26 PM
RCars2
Jan 11, 2008 06:57 PM
hamoni1
Dec 6, 2005 07:39 PM
