2000 blazer 4door 4.3 oil leak
Old Aug 24, 2024 | 04:47 PM
braden737's Avatar
Default 2000 blazer 4door 4.3 oil leak
My blazer has been leaking oil for a few years but the prior owner (my sister) didn’t do anything about it. It tooks to be leaking from deeper inside because its all over the pan. It only leaks a little per day, but if you park it for like 3 days in the same place it will have a 6 inch wide puddle. Perhaps would some of that leak sealer that you put in when you fill the oil work or atleast better the leak?
Old Aug 24, 2024 | 09:53 PM
Don't use the stop-leak products. Chances are it can be fixed properly.
Many of, if not all came within a remote oil-filter and extra oil cooler.
This means there is plenty of hardware external to the engine that could be leaking.
The most likely culprit are the hoses between the adapter at the block to the remote oil filter assembly.
The next likely culprit are the gaskets and o-ring at the adapter.
BaconBritches
Aug 12, 2021 07:07 AM
medicineman2011
Dec 26, 2017 01:56 PM
travler
Oct 23, 2014 04:23 PM
big armo
Jun 3, 2011 01:17 PM
1sexyblzr
Jun 15, 2010 01:54 PM
