2000 blazer bucking/cutting out in first gear
Old 12-09-2011 | 10:05 PM
dexx69's Avatar
dexx69 is on a distinguished road
Default 2000 blazer bucking/cutting out in first gear
Hi everyone i'm a new guy on here, I just picked up a 2000 s10 blazer with a blown motor, I have no other history on this truck.. We changed out the engine and it starts and runs fine. when i try to move it it bucks and cuts out and wants to die(only sometimes others it runs fine), different lights come on in the dash (abs,service engine soon,security light,battery) put it back in park and it revs fine. if i take it out on the road and stick my foot in it, it bucks and stumbles in first gear up until it shifts in to 2nd gear then it goes great no more bucking, also it don't seam to buck or cut out while backing up a hill..???fuel pump? ignition switch? any help would be great
Also the body (2000)has approx. 192xxx, and the motor(1998) has approx. 144xxx miles on it..
Old 12-10-2011 | 02:27 AM
trucktom's Avatar
trucktom is on a distinguished road
some codes? how about all the fun grounds on the passanger side head by the firewall? battery connections?
Old 12-10-2011 | 02:29 AM
trucktom's Avatar
oh yeah, u got the distributor in right?
Old 12-10-2011 | 11:41 PM
dexx69's Avatar
had codes checked today. it had a code for intermittent cranks sensor signal..they cleared it, i topped off the the gas tank with 12.5 gallons and the problems is still there but not as bad..also the part i dont understand is it only acts up in forward gears, in reverse it runs great...?
Old 12-12-2011 | 05:33 PM
trucktom's Avatar
could of dinged the sensor or pulled/pinched a wire take a look... its only plastic
1996BlazerSD605
07-15-2011 03:56 PM
swizznuker
02-18-2010 05:06 PM
maxell12342003
12-21-2009 04:32 PM
justDrivin
04-07-2008 06:13 PM
xtreme01blzr
10-18-2006 03:23 AM
Quick Reply: 2000 blazer bucking/cutting out in first gear
