2000 Blazer Electrical/Transmission Problems
Old Feb 5, 2013 | 06:40 PM
TessaBucklin's Avatar
TessaBucklin is on a distinguished road
Angry 2000 Blazer Electrical/Transmission Problems
I am someone that doesnt know much about cars, so I figured I would try this website out!
2000 Chevy Blazer
History of Symptoms:
2+ Years ago: Windows stopped rolling up/down
2+ Years ago: 4x4 broken (now just lights on/off)
2+ Years ago: Interior lights stuck on
1+ Years ago: Cranking but wouldnt start
6+ Months ago: Cranking but would start after 5/6 tries
This week: Slowed acceleration between 20-25 mph
Current Symptoms:
-4x4 Broken
-Cranking and starting after 5/6 tries
-Slowed acceleration between 20-25 mph
Quick Fixes:
-Removing the fuse to the cluster/ECM fixes the problem temporarily
What on earth could it be? Any suggestions?
Old Feb 6, 2013 | 05:17 PM
vonholt53's Avatar
vonholt53 is on a distinguished road
the cranking but no fire until five or six tries sounds like a fuel issue maybe pressure is not good enough or maybe a fire problem plugs plug wires dis cap rotor button my four wheel drive has quit on me a couple times but its been a vac hose thats came off both times there is one that goes hooks into the driver side inside fender u should be able to see it running under there up toward the brake fluid resevior and i know there is one that hooks on the transfer to not really sure about any more and your 4wd actuater is lookated under your battery box they go bad sometimes
Old Feb 6, 2013 | 05:22 PM
vonholt53's Avatar
i would probably start by checking your fuel pressure wit a fuel pressure gauge should be between 60-65 not go below 55 for ten min wit key on the right side of the dis cap should be were u thread the fuel pressure gauge on it will have a black cap on it just unscrew that and screw the fuel regulator gauge on hope this helps
Old Feb 6, 2013 | 07:56 PM
JAKT's Avatar
JAKT is on a distinguished road
Hi, it could be any number of things really; a bad oxygen sensor, faulty spark plugs, etc. Does the truck backfire/sputter at all when you step on the gas? If so then this could be signs of a bad fuel pump. If you can't get into second gear then it very well may be the transmission (stripped sungear).
The 4x4 issue is most likely a separate problem all together, possibly a sticky vacuum actuator valve. When you push the 4x4 button does it blink and then return to 4x2 and can you hear a clicking noise? If so then it’s most likely the actuator valve.
The only way to know for sure is to have a mechanic look at it or see if you can get a free diagnostic scan some place to determine the problem. Good luck!
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
JoSHN
Sep 14, 2012 04:56 PM
2000blazerHELP!!!!!!!1
Feb 2, 2012 11:27 PM
Duckman562
Apr 15, 2009 06:15 PM
chris24301
Jan 24, 2007 11:01 AM
