Any help would be appreciated...I am stumped
Old 03-16-2017, 10:43 PM
Thelatchkeykid's Avatar
Thelatchkeykid is on a distinguished road
Default Any help would be appreciated...I am stumped
I have an 04 with a little over 246k on it and had zero engine issues until the other day. I was driving and all off a sudden the engine was hesitating and had very little power. The exhaust smelled really rich and the engine seemed to be missing. I have changed the ECM, the plugs and wires and the injectors. It's still idling rough and smells rich. If I get the RPMs up to anything above 1,500, the engine seems to run smoothly. I'm stumped and don't know where to go from here. I need it for work. Thanks in advance.
Old 03-16-2017, 11:00 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Start with a fuel pressure and leak down test. Also look inside your throttle body at the plenum and see if you have any washed out spots to indicate a fuel leak.
Old 03-23-2017, 08:45 PM
broark2017's Avatar
broark2017 is on a distinguished road
Try unplugging the EGR and see if the power increases.. I just had that happen to my 2000 on the way to work . Would fall on its face from a take off but as soon as I unhooked EGR it takes off like a jet. Will pull and clean or replace tomorrow.
Old 03-25-2017, 12:39 AM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
2001 was the last year they used Egr valves on the 4.3l
youngbloodsno111
03-23-2019 07:00 AM
stokedstephen
09-26-2016 07:26 PM
NCSurvival
10-05-2012 01:21 PM
curtnastyy
04-19-2011 11:53 AM
BlazerPunisher
03-23-2009 05:47 PM
Quick Reply: Any help would be appreciated...I am stumped
