2000 Blazer Won't Start
Old Apr 5, 2020 | 04:45 PM
awil's Avatar
awil is on a distinguished road
Default 2000 Blazer Won't Start
My Friend has a 2000 Blazer we use for a farm run around rig he let it sit a month or so and the battery was dead he jumped it and moved it into the yard it sat there probably 2 weeks, the battery was dead so I charged the battery. I can hear the fuel pump when turning the key to run and it fire and run for a second or 2 and die and crank and crank it will run off either if we spray it into the throttle body. He thought we should change the cap and rotor which I did but knew it wouldn't fix the issue which it didn't. What do you guys think could cause this? I watched a video on a 98 blazer doing the exact same thing and the guy said he changed the spider injector and it fixed the problem, does a 2000 have that also?
Old Apr 15, 2020 | 02:04 PM
okiebezer's Avatar
okiebezer is on a distinguished road
It should have spider assembly under the upper plenum. In my case, Jimmy wouldn't run without squirting spray in the throttle body. Even then was very rough. I replaced the spider assembly with an improved, aftermarket one from RockAuto and it fixed the issue. there is a pressure regulator built in to the unit that keeps the fuel pressure up after shutting off motor. When it goes bad, pressure bleeds off and is starved for fuel.
Took about 3 1/2 hours start to finish under a shade tree. Good luck.
Old Apr 15, 2020 | 11:27 PM
awil's Avatar
Thanks for the response! I think we will start with trying the spider assembly.
Old Apr 16, 2020 | 04:25 PM
I seen cap and rotor was done. How old are the wires and plugs?
Old Apr 16, 2020 | 05:23 PM
awil's Avatar
That I don't know it ran fine before it wouldn't start, I wouldn't think the plugs and wires would be keeping it from starting if it runs off starting fluid.
Small Arms Collector
Feb 17, 2020 12:14 PM
spiderx
Nov 23, 2012 12:03 PM
bigswollenpancreas
Jan 18, 2011 10:18 AM
MB31
Sep 25, 2010 06:21 PM
justin1795
Feb 6, 2009 08:33 PM
