2000 chevy blazer
Old May 17, 2010 | 10:44 PM
brandon01's Avatar
brandon01 is on a distinguished road
Default 2000 chevy blazer
I have a 2000 Chevy blazer with a 4.3 in it. When I tow something with it the temp gauge reads around 197 when warmed up. Then if I shut it off and start it back up the gauge will read over 200 the needle will fall back to 197 after a couple of seconds. Is this normal? It has a new radiator in it and also new head gaskets.
Old May 18, 2010 | 06:30 AM
rriddle3's Avatar
Doesn't sound out of line to me.
Old May 19, 2010 | 03:07 PM
brandon01's Avatar
I drove it today I guess the needle hangs a little below the 210 mark when warm. The when I started it the needle was between the 210 and 260 mark. But it fell back to the 210 mark pretty quick.
Old May 19, 2010 | 05:29 PM
Benedict1337's Avatar
I wouldn't worry about it unless it stays that hot
Old May 20, 2010 | 11:49 PM
AJBert's Avatar
That is what is known as heat soak. As long as the engine is running, the water pump is providing coolant throughout the engine. When you shut the engine off, the heat is still there but no coolant is flowing. Thus, when you start it up shortly afterwards the temp guage is going to read higher initially until the coolant starts to flow and do its job.
In other words, what those said above. Nothing to worry about.
ChevyMane808
Apr 5, 2013 10:51 AM
bc09
Mar 25, 2010 08:34 AM
smitty1244
Tires and Wheels
Dec 5, 2009 01:52 PM
laurence
Jun 9, 2008 08:37 AM
jonmouse
15
Jan 30, 2006 09:43 AM
