2000 Chevy Blazer 4X4
Old Aug 15, 2012 | 08:16 PM
Chiisu's Avatar
Chiisu is on a distinguished road
Exclamation 2000 Chevy Blazer 4X4
I've been having an issue with acceleration mostly in reverse but it has happened in drive as well. The issue is that when I press the gas the blazer doesn't move. It revs up but stays in place. What is weird to me is that as soon as I let off the gas the blazer will move in the direction I intended the vehicle to move. This only happens after starting up the truck. Once I come out of reverse and into drive if it doesn't do it in drive I don't have a problem again until after I let the blazer sit turned off for a while.
Things to factor:
'Check Engine' light is on (I haven't hooked up the truck for readings)
New spark plugs and plug wires
This does seem to only happen on a incline now matter the degree.
Old Aug 15, 2012 | 08:36 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
look at the trans fuse see if its blown. then check for voltage, should be 12v. if not then ingtion switch is bad
Old Aug 15, 2012 | 08:41 PM
Chiisu's Avatar
Thanks for the quick reply I'll check that out and get back to you.
Old Aug 15, 2012 | 08:56 PM
Rottidog's Avatar
Check trans fluid, color, smell, get the codes read & post em up/look them up.
Old Aug 15, 2012 | 09:07 PM
Rottidog's Avatar
I had deja vu there for more than a few seconds mychevy!
Another thread we are part of was the same answer from you - trans fuse.
For a moment I thought the OP had another nic lol.
Old Aug 15, 2012 | 09:08 PM
lol yea seems to be runnin alot lol
Bradley2424
Mar 19, 2010 01:20 PM
crags
Nov 21, 2008 02:25 PM
crags
Nov 20, 2008 09:16 AM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
ptwarrior92
Jan 31, 2007 03:01 AM
