2000 Starting problems -timing??
Old Sep 27, 2011 | 09:22 AM
ace1972's Avatar
ace1972 is on a distinguished road
Default 2000 Starting problems -timing??
4.3 Vortec...I had a used engine with 150,000 km put into my truck. They had to redo the plug wires and a put a new oil pump on as well. Now the truck stutters and coughs and acts hard to crank-mostly when cold, and she shudders alot, when it does start. Had my uncle, a mechanic look at it and he said timing was off..but these trucks have the computer set the timning I believe...
Can someone help here? going back to the shop that put my used motor in is not an option as they did it cash....
starter is brand new too..
Old Sep 27, 2011 | 09:32 AM
The distributor can be adjusted (it's a loose fit into the bore through the lower intake manifold), but it requires a scan tool capable of displaying 'CMP Retard' in order to set it to zero.
If they pulled the distributor, it is possible it isn't even installed correctly. Take a read through the Tech Article (DIY) Index link in my signature below for the EDI Engine Timing thread. Run through it all just to be sure.
Old Sep 27, 2011 | 06:47 PM
ace1972's Avatar
Thanks for the helpful info. Will let you know how things go....
Doctorvette
Nov 5, 2012 11:57 PM
greg jordan
Jun 9, 2011 05:50 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
