2002 blazer driving me insane.
Old Dec 11, 2012 | 08:38 PM
czrbmx's Avatar
czrbmx is on a distinguished road
Default 2002 blazer driving me insane.
i have 4.3 vortec blazer. driving home from work on the freeway going 70 it bogged out on me and wouldnt go over 45 mph or go over 3500 rpm. ive switched out my catalytic converter put a flowmaster on while i had all that stuff out. thought it was my cat originally. it was't. has 160,000 miles on it so i did a complete tune up. new distributor cap, plugs and wires. new mass air flow sensor and i have the same problem. i dont have a check engine light so i cannot do a diagnostics test. im getting a few different things from people here in town. im tired of buying and replacing parts that dont need replacing. some are saying a solenoid some say a clutch fan, none of that makes sense to me. anybody ever have the same problem or have any idea. im about to set the mother ****er on fire
Old Dec 11, 2012 | 08:58 PM
rockp2's Avatar
When it bogged down did your engine temp go up also? Did you take a look at your oil? What you experienced is the same thing I did when my head gasket went.
If there is no coolant in your oil. I'd bet dollars to doughnuts that all of the highly experienced folks (I'm not claiming to be one of them) on this forum will tell you to start with a fuel leakdown test. This is just one of the recent threads that describes how to do this https://blazerforum.com/forum/2nd-ge...rt-cold-75428/ You will find a description how to do the test on page 3 of the link.
Old Dec 12, 2012 | 12:32 AM
50lb_cat's Avatar
Sounds like it may be a transmission issue if it won't shift to a higher gear.
Old Dec 12, 2012 | 06:16 AM
Irocz327's Avatar
Irocz327 will become famous soon enough
Did you have any problems with the abs light being on or the speedo not working? If so check your vss sensor on the trans output. That's the issue I had awhile back.
Old Dec 12, 2012 | 06:04 PM
debdoodle's Avatar
debdoodle is on a distinguished road
i fell your pain my wifes blazer did the same thing i replaced the converter with the same out come i got to looking at it and it would run fine til i got the rpm up here to find out there is a different size pipe in front of the converter( between the motor and converter).called the local auto parts store and they want 400.00.so i just cut it open cleaned it out and welded it back closed.if you have a welder and a grinder the only thing it will cost you is time and cut off wheel and welding wire
Old Dec 12, 2012 | 07:06 PM
CAB's Avatar
CAB
CAB is on a distinguished road
I would change the fuel filter.
Old Dec 12, 2012 | 08:17 PM
rockp2's Avatar
Maybe it's the color of your Blazer! Well....we mentioned just about every other part of the truck...all the was left over was the paint color to cover the entire thing
Old Dec 13, 2012 | 08:27 PM
mm12's Avatar
mm12 is on a distinguished road
I have a 00 blazer 4.3 the tack goes crazy and bogs down it seams like it does it under a load I have already replaced the plugs,wires,transmission speed sensor, crankshaft sensor, cam sensor, TPS. I have even checked crankshaft sensor for marks and found some so I also used shims but nothing any help please?
Old Dec 13, 2012 | 08:48 PM
LeWhite's Avatar
scan tool
Old Dec 13, 2012 | 09:20 PM
mm12's Avatar
I don't have any codes or check engine on! Even though my scanner would not pick up anything I had a friend mech put his high dollar scanner and it picked up cylinder six miss fire that's wen I replaced spark plugs, wires and also checked compression & cap and rotter they checked out good! Could it be the injector but would it also make the tack flicker?
ZaBlazer99
Aug 11, 2012 11:37 AM
Blade_24k
Jun 24, 2012 12:09 AM
dutchs98blazermarkIII
Nov 20, 2010 09:24 PM
Crashes
Nov 26, 2006 11:39 PM
wilds_dog
Oct 28, 2006 11:52 PM
