2003 4.3L 4x4 no start condition. Help?
Old Oct 26, 2016 | 09:56 PM
Nhackert's Avatar
Nhackert is on a distinguished road
Question 2003 4.3L 4x4 no start condition. Help?
Hello,
My 2003 s10 blazer LS v6 2door 4x4 will not start. It cranks and you can hear the odd piston fire but will not start. New battery in April 2016, It has been sitting for probably about 6 months but I started it and let it run for about half an hour once a week then all of a sudden it wouldn't start. Battery was drained to the point it would even crank but I charged it and it would crank again but no start. This all started to happen after the battery was drained. Also, something seems to be sweating, not sure what it is or what the fluid is. All suggestions, questions and comments are welcome.
Thanks.
Old Oct 28, 2016 | 10:29 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
are there any codes coming up? if so what are they? have you checked fuel pressure, is the fuel pump turning on?
Old Oct 28, 2016 | 11:30 PM
Nhackert's Avatar
Plugged in an OBD II twice with the key on and it didn't turn on. And I haven't, I don't have the tools for it right now
Old Oct 29, 2016 | 12:11 AM
richphotos's Avatar
Try spraying carb cleaner into the throttle body while turning it over and see if it fires.
If it does, most likely a fuel issue. If it does not. I would look at secondary ignition issue (plugs, wires, cap, rotor ect)
Old Oct 29, 2016 | 12:12 AM
Nhackert's Avatar
Ok thanks man
sowellj22
Dec 12, 2015 07:28 AM
calee4nyaboy
Feb 11, 2013 06:43 PM
msfan324
Jun 21, 2009 06:50 PM
hotrod28
Oct 14, 2007 09:37 PM
hogspeed
17
Aug 6, 2007 07:07 AM
