2004 blazer transmission?
Old Apr 13, 2019 | 09:12 PM
Jhnsn1985's Avatar
Jhnsn1985 is on a distinguished road
Default 2004 blazer transmission?
Had my transmission rebuilt 2 1/2 years ago about 30k miles later. The other day my truck is driving fine and boom wont go. I got it towed to my local garage and the next morning the mechanic says its driving fine. Later the same issue happens. He drops the transmission pan fluid looks good, replaces both solenoid,fluid, no shavings in the filter. Runs for 20 min and then same thing wont go. Any ideas?
Old Apr 14, 2019 | 01:39 PM
Is it a 4WD? Maybe your transfer case is going into neutral.
Old Apr 14, 2019 | 06:48 PM
Transman304's Avatar
Very possible you have a torque converter failing. Did you have the filter changed? Also as @Tom A mentioned if 4x4 try it in 4low when it quits moving. Good luck.
Brad
NipZ
Nov 16, 2017 03:48 PM
S10BlazerFTW
Apr 26, 2013 04:43 PM
jezzika39
Aug 21, 2012 01:15 AM
Mitch14290
Jul 20, 2011 09:52 AM
old96blazer
Mar 6, 2009 06:22 AM
