Transmission question
Old Apr 16, 2019 | 08:14 PM
peenar's Avatar
peenar is on a distinguished road
Default Transmission question
Would a 4l60e that has a code 4kcd work with my 96 blazer? I believe tha trans code means that it was bolted to 2004 5.4l? Bellhousing is different.
What would be the code for 96 4.3l?
Old Apr 16, 2019 | 08:23 PM
cleburne red's Avatar
Chevy never had a 5.4, did they? You mean a 5.3? I'm pretty sure the bellhousings were different between ours/gen 1 V8 and the LS engines.
Either way, I'm talking outta my rear end, and hopefully Transman shows up!
Old Apr 16, 2019 | 08:45 PM
peenar's Avatar
Wish I could just look at my trans. It's still in there lol
Old Apr 17, 2019 | 12:07 AM
peenar's Avatar
I guy wants to sell me a good trans. From the pictures the tag looks like it says 1FAD
Old Apr 17, 2019 | 11:34 AM
Transman304's Avatar
GM made a 5.4 (327) You need to see if your transmission is a one piece or 2 piece case. If its a one piece case they will not interchange. If a 2 piece you will have to swap bell housings. The stall on the converter is a bit different on a V8 vs. 6 cylinder. So use the converter that comes with the replacement. Be sure to flush cooler and cooler lines well! Good luck.
Brad
Old Apr 17, 2019 | 12:49 PM
Originally Posted by Transman304
GM made a 5.4 (327)
Oh, my bad. I've never heard a 327 referred to as a 5.4L. Always learning new stuff
princered72
Sep 24, 2012 07:56 PM
MonkeyGein
Aug 23, 2011 05:30 PM
speterson1011
Dec 6, 2010 01:23 PM
96ProjectHighLife
May 26, 2010 11:49 PM
noom14921992
Nov 12, 2008 09:23 PM
