2004 Chevy Blazer Not blowing Hot air.
Do you know if it is actually switching the actuator door between hot and cold? If not does your 4x4 work? I say this because if it doesn't work you might have a vacuum issue. If you think all of that is fine then I would just give your heater core a good flush and see if that helps.
Mine was blowing luke warm air when I first got it. I flushed the heater core a few times real good and the heater started working good after that.
That door is operated by an electric motor. But regardless, it's a good thing to check out.
Yes mrspeedy69 the actuator door is working as is the 4X4. Diaita the radiator and reservoir are at proper levels. I went ahead and changed out the Thermostat with one at 195 degrees, this I think has solved the problem. The old one I beleave was stuck closed. I will more than likely go ahead and flush the heater core if I get some decent weather, couldn't hurt. Thanks to you all
