2004 Chevy Blazer Not blowing Hot air.
Old Dec 13, 2012 | 05:53 PM
chris015's Avatar
Originally Posted by jchowell1
Yes mrspeedy69 the actuator door is working as is the 4X4. Diaita the radiator and reservoir are at proper levels. I went ahead and changed out the Thermostat with one at 195 degrees, this I think has solved the problem. The old one I beleave was stuck closed. I will more than likely go ahead and flush the heater core if I get some decent weather, couldn't hurt. Thanks to you all
Thermostat is usually the culprit. if shes blowing hot now you scored.
putz1699
Jun 11, 2014 06:13 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
bl_zer
Nov 23, 2008 11:14 PM
ItradeNDX
Feb 3, 2006 05:21 PM
