2021 Blazer RS transmission fluid change
Should be the same as a Traverse, as long as it is a 9-speed. Problems, or just maintenance? I have heard these are finnicky transmissions.
https://www.traverseforum.com/thread...service.20346/
Is it shifting funny? If fluid burnt from slipping and/or getting hot? Trans shifting is controlled electrically by the computer and solenoids. Tell me more about your issue and I'll see what I can find.
It shifts just fine, the only problem is that shudder at 1500 rpms. I did check the transmission oil and it looks dark and smells burnt. The shudder always happens when accelerating only.
Well I suppose that damage might already be done if fluid is burnt and dark. I suppose that all you can do yourself is to change the fluid and see if it helps any. Sorry! If it does fix it, please let us know.
I will let you know for sure, thanks again.
aaron1651
Mar 26, 2008 12:18 AM
