Transmission Fluid Question
Old Jan 12, 2009 | 12:00 AM
mwacker's Avatar
mwacker is an unknown quantity at this point
Default Transmission Fluid Question
I just bought a 97 Blazer with 115k on it. The transmission seems fine and the fluid is nice and red. Should I change the transmission fluid, by dropping the pan and replacing the filter and gasket? I doubt the previous owner had it serviced... Which is more risky changing the fluid or leaving it?
Old Jan 12, 2009 | 06:49 AM
Default RE: Transmission Fluid Question
If the fluid is nice and red, then it was probably changed already. If you want to change it again, that is your call. If everything is working properly and the fluid looks good, there may not be a need.
BrinkDiamond
Mar 2, 2014 03:50 PM
keech
Aug 8, 2013 04:17 PM
DaleA
Jan 13, 2009 08:50 PM
p_j_robertson
Jul 3, 2006 09:52 PM
medion42
Mar 16, 2006 10:18 PM
