2021 Blazer RS transmission fluid change
Old Feb 26, 2024 | 12:37 AM
matt.mrtnz's Avatar
matt.mrtnz is on a distinguished road
Default 2021 Blazer RS transmission fluid change
Hello, can someone lead me into changing the transmission fluid? I can’t find anything online how to go about it. Thank you 🙏
Old Feb 26, 2024 | 06:44 AM
LesMyer's Avatar
Should be the same as a Traverse, as long as it is a 9-speed. Problems, or just maintenance? I have heard these are finnicky transmissions.
https://www.traverseforum.com/thread...service.20346/
Old Feb 26, 2024 | 11:57 AM
matt.mrtnz's Avatar
Problems, it hesitates at 1500 rpms. I read online to change the transmission oil to see if it would go away. Thank you for replying.
Old Feb 26, 2024 | 01:42 PM
LesMyer's Avatar
Is it shifting funny? If fluid burnt from slipping and/or getting hot? Trans shifting is controlled electrically by the computer and solenoids. Tell me more about your issue and I'll see what I can find.
Old Feb 26, 2024 | 02:25 PM
matt.mrtnz's Avatar
It shifts just fine, the only problem is that shudder at 1500 rpms. I did check the transmission oil and it looks dark and smells burnt. The shudder always happens when accelerating only.
Old Feb 26, 2024 | 06:59 PM
LesMyer's Avatar
Well I suppose that damage might already be done if fluid is burnt and dark. I suppose that all you can do yourself is to change the fluid and see if it helps any. Sorry! If it does fix it, please let us know.
Old Feb 26, 2024 | 09:14 PM
matt.mrtnz's Avatar
I will let you know for sure, thanks again.
Schrade
Oct 3, 2016 04:43 PM
LannyL81
Aug 27, 2014 06:15 PM
XBlazer01
Dec 2, 2009 03:37 PM
mwacker
Jan 12, 2009 06:49 AM
aaron1651
Mar 26, 2008 12:18 AM
