205 crossmember drop
Old Jun 11, 2015 | 03:04 PM
jbaker's Avatar
jbaker is on a distinguished road
Default 205 crossmember drop
I have a 87 K5. TH350 trans with a NP205 transferase, my issue is I lifted the blazer 6 inchs and now I can't get the transmission or the transfer case bolted to the frame. I know the 87 didn't come with a 205 so the cross member i have dosn't work at all, id have to use 6in blocks between the frame and crossmember to make it work. Any advice out there on similar builds or any after market parts that may solve the issue.
Attached Thumbnails 205 crossmember drop-img_0931.jpg   205 crossmember drop-img_0934.jpg
Old Jun 11, 2015 | 03:16 PM
Rough Country as well as a few other manufacturers sell transfer case drop kits that lower the t-case a few inches. They are nothing but heavy wall spacers and longer grade 8 hardware.
You should not need to drop it much more than that for a 6" lift. Go too far and your front driveshaft angles will be really screwed up. Your angle already looks way out with it that far down. Beyond the typical 1-2" transfer case drop, the t-case generally gets clocked to improve front driveshaft angles.
Why do you have it down that far? Is the t-case hitting on the underside of the body?
Old Jun 11, 2015 | 03:39 PM
jbaker's Avatar
Default 205 transfercase drop
Thanks for the reply, but the more I raise The T case the worse the drive shaft angle gets. I used a rough country drop kit and wasn't enough. even with custom drive shafts the angle is a no go.
Old Jun 11, 2015 | 06:49 PM
The worse what drive shaft angle gets? The front or the rear? You have to work with both unless you want to have a lifted truck with no power going to the front...
Dropping the entire cross-member results in HORRIBLE angles for the front shaft. That is why you can only drop it so much before you get in a bind, literally. So you can only drop it so much to get the back in a happy place (with the right shaft) and then correct the front by clocking the t-case (twisting it with a custom mount to lower the front output). Just look at your second picture that shows the front output and the input on the front axle. In the front, there is no way you are going to get a driveshaft to be happy in that scenario even with a CV style driveshaft like what is in there stock.
For the rear output, with that much of a lift, you should have already gone to a fixed yoke on the transfer case and a CV style joint at the t-case.
97Bravada
Tires and Wheels
Jul 21, 2010 01:05 PM
fatsjames
21
Nov 28, 2009 08:30 PM
ImScrewed92
Tires and Wheels
Aug 22, 2009 07:21 PM
russplmb2
Jun 9, 2009 07:29 PM
mdemers2006
Jul 26, 2007 06:41 AM
