2wd to 4wd to 2wd issue
Old Jan 25, 2019 | 07:55 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Default 2wd to 4wd to 2wd issue
I've been searching the site for a similar problem but I haven't had any luck. Sometimes when I start up the rig the 4wd switch on the dash (4 button) is in 2wd. On its own it will shift into 4 lo. When I push the 2wd button it blinks but sometimes stays in 4 lo. If I push the auto button the auto light comes on steady. Other times it goes back to 4 lo. Sometimes when I start up the rig it's in 4 lo when it was in 2wd after parking and shutting off the engine. I've checked all the vacuum hoses which I replaced this last summer using Christines thread and I don't find any issues. Possibly an erratic 4 button switch?
Old Jan 25, 2019 | 09:08 PM
cleburne red's Avatar
Might be worth it to check the switch out. Or maybe unplug it completely and see how it acts
If you are lucky, maybe find one in a junkyard for cheap, and see if the behavior persists. If your junkyards are like mine, though, they've all been long since picked up lol
Old Jan 25, 2019 | 09:31 PM
G0LFADD1CT's Avatar
If I unplug it will it stay in 2wd?
Old Jan 25, 2019 | 09:54 PM
It should. That's how my 95 works. Not sure about the later ones with auto 4wd
Old Jan 26, 2019 | 10:04 AM
go chevy's Avatar
Same on my 98 Blazer, if you unplug the 4x4 switch it should stay in whatever range you had it on when it was unplugged... But like cleburne red said, mine is also the 3 button switch so I have no real info on the 4 button setup... I would think though if it keeps jumping around while unplugged you might want too call a priest too see if it is possessed
Old Jan 30, 2019 | 03:46 PM
LesMyer's Avatar
Is it really in 4WD-lo when the 4WD-lo light is on steady? Encoder motor has a position sensor that the TCCM reads electronically and then illuminates the appropriate light in the selection switch. Sounds to me like the TCCM is getting the wrong info from the encoder motor, unless it is really in 4Lo. Probably encoder motor issue, but could be TCCM interpreting wrong. Only thing it is highly doubtful to be is the selection switch (which just houses the little lights in the buttons that the TCCM operates)
Old Feb 11, 2019 | 04:44 PM
G0LFADD1CT's Avatar
It hasn't shown up again, but now when selecting 4 hi and putting it in D or R I can hear the shift take place. When I press on the gas pedal nothing happens at first and then it bangs and starts moving. Wish I had a garage....
Old Feb 12, 2019 | 10:38 AM
go chevy's Avatar
How long has it been since you checked/changed your differential fluid? Just a thought...
Old Feb 12, 2019 | 10:56 AM
Don't think diff oil would make a difference. The rear end doesn't know or care what the transmission is in, only if the driveshaft is turning
LesMyer
Feb 11, 2015 07:25 AM
scottspeer
Oct 6, 2013 08:38 PM
James Honey
Nov 11, 2012 11:11 AM
jjnemoiii
Sep 15, 2011 09:54 PM
CB160
Jul 14, 2010 11:27 PM
