350 with a 4L60E transmission
Old Dec 21, 2012 | 11:07 AM
ChevyBoii91's Avatar
ChevyBoii91 is on a distinguished road
Exclamation 350 with a 4L60E transmission
i have a 91 blazer & i wanted to know will a 350 motor bolt up to my 4L60E transmission... or should i put a 4.3 back in?
Old Dec 21, 2012 | 02:43 PM
abig84's Avatar
yeah they have the same bellhousing. so technically it will bolt up i just dont know what it takes to work properly, like what fly wheel you need and any kinda computer issues or stuff like that.
Old Dec 21, 2012 | 02:58 PM
Diaita's Avatar
I dont think they were electronically controlled in 1991. a 4L60
Old Dec 21, 2012 | 03:23 PM
rexmburns's Avatar
Super Moderator
Yeah I believe you should have a 4L60 with a kickdown cable rather than the 4L60e which diata already noted as the electronic version. If that's the case and you are trying to mount a carbureted 350 to it you should be ok as long as you hook up the kick down cable. Like big said you may need a different flywheel and possibly torque converter. If you do indeed have the e then you will need a newer injected motor and computer programming and such to get it all to play nice. Do some searching online and you will find alot!
Old Dec 22, 2012 | 10:39 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
You should be good as the electronic version didnt come out till 92,You will need a flywheel from 91 trans to work also.
Old Dec 22, 2012 | 01:22 PM
abig84's Avatar
i never knew there was a non computer 4l60. so basically gm just retaged the 700r4. good to know
dj00140
22
Nov 4, 2015 05:03 AM
tech180
Feb 2, 2013 10:23 AM
quinn1991
Sep 27, 2009 09:31 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
