4.3 TBI stumbles when warm
Old Jun 26, 2017 | 01:37 PM
debago77's Avatar
debago77 is on a distinguished road
Default 4.3 TBI stumbles when warm
My son got his first truck and has some issues. It's a 1994 S10 4.3 TBI. 2wd, auto. 132k miles.
It runs like a champ for about 5 mins. Then it falls out its face has zero power almost. Barely can pull itself to 30-35mph without bucking and stumbling and surging.
I have replaced IAC, ICM, and fuel filter this weekend and still no change.
It know will run a rev up in park or neutral, but immediately dies when placed in gear.
Any thoughts?
Thank you!
Old Jun 27, 2017 | 01:48 AM
Some possible causes come to mind:
- Coolant temp sensor. Does the dash provide temp indication that looks correct? The other sensor is for the overheat warning light if i'm correct.
- Battery voltage (do yo have to jump start the car?) Below 9 V on the electrical system the IAC is not working. Same if voltage goes over 16 V. Check with car gauge or volt meter
- Electrical and wiring problem with the sensors. Check all electrical connectors - clean, spray with a contact spray. Check wires for grounding and damaged insulation.
- TP sensor (at closed throttle the voltage should read below 0.85 V)
- TBI fuel leaks? (you would have smelled that one)
- Injector harness (damage or disconnect)
- Check that both injectors actually work. Spray pattern should be visible. CAUTION with open air filter element! FUEL = ignitable! Make sure you understand the precautions and safety measures to be taken.
bigbadjer
Sep 8, 2018 06:12 AM
ddog800
14
Feb 16, 2011 03:01 PM
duff
Oct 5, 2009 11:08 AM
hotbloodsx3
Apr 2, 2007 07:08 AM
Inferno
Oct 22, 2006 08:56 PM
