4 wheel drive
Old Feb 26, 2009 | 11:43 AM
blaze 1's Avatar
blaze 1 is an unknown quantity at this point
Default 4 wheel drive
my front end doesnt engage when i put it in 4. when i put it in 4 low the rear is low but the front doesnt i replacet both axels in the front it doest grind or make any noise could it be the vacuum line that ingages it
Old Feb 26, 2009 | 11:44 AM
blaze 1's Avatar
Default RE: 4 wheel drive
by the way its a 1992 s10 4.3
Old Feb 26, 2009 | 12:35 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
could be vac related (first thing i would check personally) start with pulling the cable from the actuator to the front axle by hand and clamp a pair of vise grips on to hold it there and test if 4wd is working, if so then you more than likely have vac problems.
mirrorimij
Jun 8, 2019 03:34 PM
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
afranchetti
Jan 6, 2010 01:24 PM
carterx
May 21, 2009 08:30 PM
