4 x 4 wheels not engaging
Old Apr 20, 2008 | 06:37 PM
bigt's Avatar
bigt is an unknown quantity at this point
Default 4 x 4 wheels not engaging
I have a 1984 S 10 Blazer 2.8 4 x 4. Put in a shift lock cable to get rid of acuator thinking that was my problem. When I shift into 4 wheel drive the transfer case locks in but the front wheels won't engage. Any suggestions? Thanks
Old Apr 20, 2008 | 09:19 PM
blazinrebel's Avatar
blazinrebel is an unknown quantity at this point
Default RE: 4 x 4 wheels not engaging
do you hear any grinding or any other weird noices after the 4x4 is engaged?
Old Apr 21, 2008 | 11:57 AM
bigt's Avatar
None??
Old Apr 25, 2008 | 09:18 AM
bigt's Avatar
The front drive shaft will spin when engaged. I pulled the cable out and took a pair of pliers and pulled on the shaft to try and make it engage and no luck. What should I do next? Thanks
Old Apr 25, 2008 | 11:24 AM
94blueknight's Avatar
94blueknight is on a distinguished road
double check all ur vaccum lines first and then if thats still all good and it wont engauge then its something in the front diff. prolly the shift fork
Old Apr 27, 2008 | 06:16 AM
bigt's Avatar
Any info online for tearing it apart? Thanks
seriosbrad
Nov 7, 2015 09:08 PM
2000silverado
Sep 4, 2011 11:08 PM
peacher213
Apr 15, 2010 03:42 PM
chrisblaze
Dec 6, 2009 12:27 AM
bigt
Apr 21, 2008 11:58 AM
